RCU Forums - View Single Post - Dominator Problems
Old 03-06-2004 | 02:41 PM
ChrisSpad
Default RE: Dominator Problems
CG sensitivity can sometimes change depending on how the wing is folded and glued, so the balance on the spar, although a good starting point, may not be perfect. Also, the ailerons have to be level with the fuselage or slightly reflexed. What you describe is directly related to aerodynamically drooping ailerons or tail heavy or a combo of both. Bring the ailerons up and try it, if that doesen't help, move the CG forward, and I'll bet you'll have a whole new airplane.
listen to whats been said already. Its tailheavy, and chances are the ailerons need to be raised up about 1/8" above parallel to the fuse, at the trailing edge. Move the wing back 1/2" as well, and i bet it flies like a totally new plane.
