Hi there Mikenlapaz!!
It is made by King Canada and is model: KC-161SSC and the price I think was ( as it was a gift) 79.00Can The main blade does NOT pivot as it is fixed as show-in the Table top will offset to 45dg. I found it to be Awe some to work with.
I do like the round saw blades that you can get for it (teeth are all around the blade 360dg so you can make your cut going one way then and with out stopping change to what ever dg that you want and keep going) .
The arm is 16" >>>The Drill is Model KC-108C 8" press and the Belt/sander combo is Model KC-702C.
Don Hattend and I have a thread called Super Strikemaster >>>Do a search for it, all work that you see on my Proto #2 was done with the above tools.
ORIGINAL: mikenlapaz
Blade47
I like your selection. Using a friend's scroll saw and shopping for combo sander. Does your scoll saw blade mount at 90 degrees in addition to aligning with arm? If so what make and model? $
Length of arm on scroll saw is not terribly important if you can rotate the blade. Give you the benefit of cutting long material like on a band saw.
I would add a Dremel Moto Tool with flex shaft to the items Blade has pictured.
