RCU Forums - View Single Post - New CA models Epsilon build (easy as pie)
Old 03-07-2004 | 05:12 AM
3dUkidding!
Default New CA models Epsilon build (easy as pie)
Then we join the sides together and put the 1/4 square along the bottom of the fus and put all the formers on.[img][/img]
We then need to make sure all is square and tight
[img][/img]
We need to make sure there is clearence for the double F9 tailwheel support. I trimmed the 1/4 balsa for a perfect mechanicle joint.[img][/img]
and just drop the other side on
ID:	108640   Click image for larger version
ID:	108641   Click image for larger version
ID:	108642   Click image for larger version
