RE: My B4!!
hi guys i know this may sound stupid to some but here goes....
brushless motor r very efficient. so much so that they can be geared alot harder compared to a brush motor. therefore the best method (well for me anyway) to check if the motor is running at it's peak is to use your hand. if u could hold the motor for ever without pulling ur hand away, u probably undergeared it. try another 2-3 teeth up on the pinion, as long as u can hold the motor for more than 6sec without pulling ur hand away u r save. once u got the pinion rite, use the spur to gain more top end or pick up as spur does not effect the ratio as much as the pinion. normally i just stick to the same spur.
this way i normally found that i still have all the pickup i want with the additional top end. it so much so more important in off road as u want to hit the gas as early as possible without getting to much wheel spin and this happen alot to my fellow peers as they undergeared thier cars.
hope this info help ^^.
