I just cut and pasted from
www.hobbypeople.net They have it for 79.99. I will not be able to fly it today, but as soon as I do, I will let you know.
Red
Specs:
Wing Span: 40.5 inches
Wing Area: 390 square inches
Length (overall): 34.50 inches
Weight (ready to fly): 27-29 ounces
Wing Loading: 10-11 ounces per square foot
Functions: A/E/T/R
Features:
Covered with lightweight transparent covering
Wing and stabilizer hand-built using balsa and plywood
Fuselage is molded fuel proof plastic with plywood and balsa sub-structure
Uses commonly available mini radio equipment
Custom lightweight hardware
Aluminum landing gear
Easy to finish and fly
Recommended Equipment
Spinner (1.5 inch, Magnum Alum 237150)
AP 15 ENGINE
4 channel radio minimum (with either a Y-harness or aileron servos)
Cirrus CS-18 servos (5)
8x4 propeller
Fuel line (Global 115923)
