RCU Forums - View Single Post - u-can-do 60
Thread: u-can-do 60
Old 03-07-2004 | 03:28 PM
  #179
rfw1953
Default RE: u-can-do 60
Roger, sorry for your loss.
Who lost what? Jeff, one other thing. The remote glow only helps when starting the engine. After you remove the glow starter from the remote glow it serves no function. It's simple a power relay to the primary on the engine.
autoguns - I fuel proof the inside as well, but still don't like exhaust going inside the fuse. Get's everything all oily inside over time. Like you said, to each his own. That’s one of the things I like about RCU. You get different options from many different people. Then you have to select the best for you. We all learn from these discussions.
I have to admit that I'm not as concerned with the weight thing that some of you are. I don't want a tank in the air either, but then I don't like foam wheels, plastic spinners etc. Trade offs with both approaches. You just have to assemble to suit your specific wants and desires. As for the mount, I purchased a mount for this engine and not real concerned about it being used with other engines. Then again, the fit is perfect, tight and no slop. I have seen guys use both. It's all a matter of what you want.
