RE: RE: RE: RE: RE: RE: RE: RE: RE: Official Nitro Evader ST Thread
Don't bother buying gaskets, make your own. Get a manilla folder & cut out a rectangle that is bigger than the gasket size. Then clean your exhaust port on your engine & lightly greese it. Carefully press the piece of manilla folder onto the exhaust port & the greese will give you a perfect outline to cut out. Once you cut it out you have yourself a gasket. I use this method for all my engines & once you get used to doing it you will become very good at it. And 1 manilla folder makes thousands of gaskets, and costs the same price as 1 gasket.
I ran the sway bar yesterday & it's broken all ready. They work really well, but are very susceptible to breaking when you run up the rear of another car.
I need new tyres. Going down to the LHS to pick up some new bow ties today.
