RCU Forums - View Single Post - Overheating YS 1.10
Old 03-07-2004 | 06:28 PM
steveg_oz
Default Overheating YS 1.10
Hi,
I have a YS 1.10 with a Hatori pipe mounted in a Swallow pattern plane. I'm running the new low viscosity Coolpower oil 22% with 20% nitro, and a 15x8 APC prop. The ambient temp was about 35 degrees Centigrade.
The engine seems to overheat, both at idle on the ground and in flight. I noticed it losing power on the last flight.
I decided to try to run it without the cowl to see if that improved the problem. The engine then promptly detonated and threw the spinner.
Do I need to strip the engine to check for damage? How would I recognize heat damage? Any idea's for a fix?
Steve
