RCU Forums - View Single Post - YS 1.10 overheating problem
Old 03-07-2004 | 08:04 PM
Eric.Henderson's Avatar
Eric.Henderson
Default RE: YS 1.10 overheating problem
It sounds like the engine is getting less fuel than it needs. I had it happen several times. (Throwing prop). The engine did not get hurt. It turned out that the regulator gasket was distorted. Fitted a new one and the engine ran propoerly.
If you have compression and no crunchy noises it should run again..
