RCU Forums - View Single Post - Cox problem solved -- but why?
Old 03-07-2004 | 08:18 PM
DICKEYBIRD's Avatar
DICKEYBIRD
Default RE: Cox problem solved -- but why?
It's hard to say without seeing it run but it sounds like your crankshaft is binding in the case. Either too tight mechanically or really gummed up with oxidized castor residue. Take the crank out of the case and clean/inspect everything carefully.
If that ain't it, like you said, it may just be plum wo' out!
