Originally posted by LUV2FLYRC2
Hi MR_ Matt. with all the time you Have spent around turbines have you seen any damage to a turbine that has been put out with a CO2 extinguisher?
Hello!
No I have never seen any damage from C02, keep what you have it is fine.
You will not need it very much anyway!
I personally use Halon, as it is lower pressure and needs a lighter bottle than C02. It is hazardous to use, and expensive.
Not sure who you are, are you coming to Prado? If so come over and say Hi. I have an F-4 in primer.
