RCU Forums - View Single Post - YS 1.10 overheating problem
Old 03-07-2004 | 11:34 PM
David Cutler's Avatar
David Cutler
Default RE: YS 1.10 overheating problem
It sounds like it's running too lean. Overheating and throwing props both say it could be.
The exhaust valve would be the first to go if it has cooked too much, and that can be checked by seeing if you have good compression. If you have, it should be OK. Also, check the valve clearances to make sure the timing isn't off.
-David C.
