ORIGINAL: ZAGNUT
i was at my LHS two weeks ago and they still had carbs, liner/piston sets, rods and a bunch of other parts. will call them in the morning and check prices, will most likely be lower than what you'll find in the states.
dave
called this morning and got prices. i do not want to take any bussiness away from US distributors so please check with them first. my only intent with this is to help anyone in need of an impossible-to-find part to keep these little jewels running.
all prices are $US:
cylinder/piston....$20
muffler...............$12.50
bushed rod.........$8
head (NOT plug)..$6.50
needle................$4.50
needle housing....$4.50
screw set............$4.50
gasket set...........$2.50
C/L venturi.........$6
R/C carb............$19
the dude at the shop said the carb is the single needle version, i've only seen the two needle version so i don't know if he just made a mistake or if the carb really did come in two versions.
i also don't have a clue as to which version the needle and housing are for...they may even be for the C/L engine.
