RE: Alternative to ZDZ 40 - I ..... the engine!!!
RMM, I had the same problem your having with the engine quiting at wide open throttle. Went through everything, new gas tank, new gas lines, new plugs, new ignition module, turned out to be the switch. Yes it was a brand new switch, but somehow the harmonics of the engine and airframe vibration, made the contacts open at WOT. Went to a HD switch and it has not even sputtered since.
