RCU Forums - View Single Post - Cox problem solved -- but why?
Old 03-08-2004 | 03:03 PM
DesignMan's Avatar
DesignMan
Default RE: Cox problem solved -- but why?
One other thing to check is varnish on the cylinder walls. If the inside of the bore is medium brown or darker, use 0000 steel wool or the bore brush sold by Davis Diesel to clean it back to bright metal.
The varnish actually gets sticky at running temperature and causes all sorts of bad running and overheating.
