ORIGINAL: lov2flyrc
Actually..... I saw the stab that came off the viper, a ball link was installed on the fiber control horn. This is a big no-no! Because this puts a side load on the horn instead of pulling evenly from both sides, the horn snapped under load and the elevator fluttered off the plane. Basimpsn did an amazing job of getting the Viper back in one piece on one stab!
Todd
Thanks for the info, Todd.
I agree with you that ball links is not a good option on FG control horns unless you install two FG horns side by side with the ball between them. I use 3mm. Kavan metal snap-links on mine, so it should be OK.
Did it happened at very high speed??
