RCU Forums - View Single Post - Scratch Built Ignition???
Old 03-08-2004 | 07:56 PM
  #155
balsa1
Default RE: RE: RE: Scratch Built Ignition???
Hi Rambo RCU
just going over some of the back posts you mention your Q35 not running well on the tim-6 ing. If I remember right we use to run thoughs at about 7 dto 7500 the 75 deg. of dwel would be excessive as I think I figured about 51 deg. at that rpm if that is correct the longer dwell would heat the coil and make it short lived well just a thought. Luck
