You should not expect the trim settings on your plane and the simulator to be the same. Every plane is a bit different, and needs slightly different trim settings to fly straight. Pain that you mess up your real plane trim settings when flying the sim. Maybe there is a way to get around this playing with the simulator radio settings.
The RF is not blocked, but your plane should be turned OFF
Carl
