RE: Reflex and Multiplex Evo
Depending on where you buy it comes with an MPX connector which works pretty nicely with MPX EVO's (actually ALL MPX radios sind Combi 80) BUT ... MPX had a problem with some EVO boards and the automatic HF cut-off. Either you check with your MPX service station first or you just remove the HF module when simulating. The problem is reproducable: just plug-in any MPX student cable or sim and turn on your EVO. If everything is fine go ahead. If you are getting funny messages on your display or detect a nasty smell it's time to see your service station and remove the HF. I tried to get in contact with MPX in order to solve the matter but they prefer to dive deep. That problem refers to anything you connect to the student socket: the original MPX student cable, an AFP sim, a G2 sim, a Reflex sim, an FMS - all the same.
Cheers - wolfgang
