RE: Trailing edge slightly upturned at wingtips?
Thinking more on this, you could determine where the surface deviates from what it should be, and cut that part off, and glue in a replacement chunk of foam, sanded to fit.
Or it's also likely the sheeting if any or covering can be installed to reduce the reflex.
Paul
