RE: Engine tests/Range test complete
Hi,
Maybe what I'm going to ask here had been asked before, so please bear with me.
I'd like to ask some questions about the Engine setting.
1. For 4 engines, are you using 4 servos ?
2. Are you using program mix for all 4 servos?
3. Do you use throttle Curve for each engine/servo?
4. Are you using Glow Plug Driver so that at idle, the glow plug will lit ?
Thanks a lot in advance n Best Regards,
NICK, Jakarta
PS. I'm building JHH C-130. plan of using OS 61.
