RCU Forums - View Single Post - Proper use of exponential servo control for sequence flying
Old 03-10-2004 | 02:41 PM
ilikeplanes
Default RE: Proper use of exponential servo control for sequence flying
I'm easily confused by the barrage of so called advise. You gotta do this and you gotta do that otherwise your flying will suffer. I started using expo because of advise. Getting used to it doesn't make much sense to me unless it will eventually lead to improved scores.
Maybe I'll cut back and work up slowly.
