RCU Forums - View Single Post - Jetcat ECU with Simjet engine
Old 06-12-2002 | 06:06 PM
mr_matt's Avatar
mr_matt
My Feedback: (10)
Default Re: Jetcat ECU with Simjet engine
Originally posted by GerhardH
Hello,
Has anyone tried using the Jetcat ECU with the Simjet engine. I am having a lot of trouble with my Simjet ECU but I think the engine will be ok with a better ECU. Has anyone done this.
Will Jetcat sell the ECU alone?
We have one system in stock, but I warn you it does not have a seperate manual you would need to refer to the normal JetCAT manuals and have us fill in the blanks via internet, no problem there i think, just trying to be thorough.
The system includes an ECU (version 4), Ground support unit (GSU), RPM sensing diodes for mounting to the turbine ( you need to figure a way, they are interrupted IR beam ususally goes through the compressor nut) and the thermocouple with adapter plugs.
It does not include a pump but should work with the Hausl pump if that is what simjet uses
Price, $US499 FOB California. There is only one left, I wish I had it, great for homebuilts!!
Contact JetCAT USA if interested (www.jetcatusa.com, (818) 874 9309) or PM me here on RCUniverse.
