RCU Forums - View Single Post - Engine Thrust Problem?
Old 03-11-2004 | 04:04 AM
tIANci's Avatar
tIANci
Default Engine Thrust Problem?
I just got a sketch built plane and I am having some problems with my maiden flight and last few flights. After getting the plane in trim I will fly it at half throttle, it holds properly. When I power up to full it pulls hard UP and RIGHT. I would then be fighting to trim it out again. What might be the cause ... engine thrust issues? The engine is mounted at 45 degrees, 10 o'clock. Thanks.
