RE: Royal Evo mixer set up
The rudder input into the elevator mixer needs to be assymetrical, not symmetrical. Then when you go into the mixers screen it gives you 2 values to set, not one. Each value corresponds to one direction of rudder stick. Remember that you can use negative values to get the travel in the correct direction.
Harry
