RCU Forums - View Single Post - why different knife edge?
Old 03-11-2004 | 08:04 AM
JPBIII
Default RE: why different knife edge?
Could also be your rudder servo, Are you using a pull-pull set up or a single rod? The pull-pull set up will give you equal throw on each side. The single rod set up (if it is a weak rod or a long way from servo to control surface) the servo will pull more than push.
Disregard I went back and re read your post about the pull-pull set up.
