RE: What Engine For WACO 30??
Dauntae
After putting the OS 40 in your Waco 30 how did the CG come out. I'm deciding between the saito or the OS 40. The OS is a little heavier then the saito. If I have to add weight to the nose of a plane to get right CG I usually gowith a larger battery or go to a larger engine that will fit. Has anyone seen the saito and OS side by side for sz difference.
