RE: slow stick ailerons?
I agree that there is no point to adding ailerons. I read all about it before I did it and had to try it anyways. In my experience it actually did work, but it drops like a brick when you pitch one wing so whats the point? Since then I have removed the ailerons and patched the hole and am just using it as it was. Its still a great plane.. once you update to the 350 motor.
Pete
