RCU Forums - View Single Post - antenna help
Thread: antenna help
Old 03-11-2004 | 04:37 PM
KW_Counter
Default RE: antenna help
Ray C.
Sorry, I don't have pictures. Each piece is about 1/2 inch long.
The piece through the bottom of the fuse is to prevent chaffing the insulation where it goes through.
I cut it off even with the fuse on the outside. I think the hole was about 1/4 inch in diameter.
The piece on the back is just there for the antenna to go through and stay next to the plane, not flop around..
It's pretty loose but doesn't seem to come out readily. You could put a piece of toothpick in it if you wanted to keep it tight.
I also used a piece in the fuse for routing purposes to keep it from the servos.
If you have any question feel free to ask.
KW_Counter
