RCU Forums - View Single Post - Engine for 60 Ultra stick?
Old 03-11-2004 | 10:39 PM
Todd D's Avatar
Todd D
My Feedback: (51)
Default RE: Engine for 60 Ultra stick?
Okay, So I decided to go with the Magnum 91XLS. For $129 you can't go wrong there. Everything is mounted and ready to go, 2 servos in the tail just forward of the vertical stab, pull/ pull on the rudder. This shoud be sweet. I do have a bit of a balance problem though. Manual states 4 and 1/8, mine needs to have the battery (standard 4.8v) all the way in the tail near the servo's and some extra lead (3 ounces) to get that balance point. Anyone else had this problem with a ultrastik and 91 XLS? From what I've read here and elsewhere this engine isn't that heavy to cause this situation. Am I missing something? Or do I just add the weight. I was thinking of going with a 6 volt battery with 1000 mah to handle all those servos, I presume that would cut down some of the lead I need to add. Any suggestions?
Todd
