RE: Homelite 30cc test
pichi,
I have one of those engines that I converted. The engine will start and run fine with the magneto. You have to cut down the fins on the front of the flywheel.
Plugging that hole will increase compression quite a bit and give it more power. I plugged it by running a tap part way in and using a set screw. Be careful not to get metal chips in the exhaust port.
That ZAMA carbureter gives poor performance. If you get the bigger carb(#28 stamped inside) the engine will really come alive.
Jim
