RCU Forums - View Single Post - AFP Question
Thread: AFP Question
Old 03-12-2004 | 02:38 PM
MAWRC 1
Default RE: AFP Question
It may be your physical setup.
Do you have it configued as one servo (channel) per aileron or one servo (channel) for both ailerons? It sounds like the later since you said ailerons on channel 1. If you only have one servo (channel) for both, it will never work since the ailerons must be controlled independent of each other.
Regards,
MAWRC 1
