RE: RE: Elevator/Rudder Servo Arms
here's one pic.I used the sullivan super rudder horn,part number s568.I had some cable left over from another project .You could also use the dubro pull-pull setup which includes everything.Since there was no hardwood block where the rudder horn mounts,I took a piece of 3/8 dowel,cut it to the proper length,drilled a hole through the center and epoxied it in.Then I took the stock control horn and dremeled off the horn so I had the two mounting plates and then drilled through those.From there,just cut the rod to the same length on both sides that the stock horn was,used a couple pieces of lite ply for a servo tray and moutned the servo under the wing bolt plate.All told I think it took me less then one hour.
