RCU Forums - View Single Post - Honesty why 10x?
Old 06-15-2002 | 04:43 AM
  #64
Gordon Mc
Default Re: They all still fall short --------------
[QUOTE]Originally posted by Silver182
Gordon: you are correct sorta about the Futaba, I say sorta because if you keep it simple, and are willing to change all primary channel rates simultaneously ------ example aileron set to low rate, elevator set to low rate, rudder set to low rate, with one condition setting, then change aileron to medium, elevator to medium, and rudder to medium, with another condition, and then the third condition set to aileron high rate, elevator set to high rate, and rudder set to high rate---------- I think you have your three position rate switch.
Hi again Lee,
Sorry, but this isn't what I'm looking for - I'm not interested in having to change the rates of all surfaces at the same time and in the same way. Futaba clearly understands this too, otherwise their radios would have a single rate switch instead of three separate ones. ;-)
Later,
Gordon
