Originally posted by Silver182
You indicated wanting a servo slow feature for flaps, well think about linking your flaps to a three position switch, and when you put the flaps full down you automatically have totally separate trims remembered for that flap setting. This is a very nice feature as it allows you to re trim completely all flight surfaces. Really handy for retriming elev and aileron to compensate for any aircraft flight angle changes upon flap deployment.
JR offers just the transmitter and case at a substantial savings over the complete system. If you already have all the receivers and servos you need this is a good way to go ---------
Lee
Everybody, I do really think you should have a serious look, without a priori, to Multiplex 3030 and 4000. You can put the slow feature on ANY command, ANY number of times. (On my previous Jet trainer, I setup 3 seconds on the throttle ). On the Maverick, I used slow on the flaps as well as a mixer on elevators, so that the change in flight attitude was smooth.
You have 3 SEPARATE high-low rate switches, and the ability to have 3 "modes" for one plane. In fact, it's 3 separate memories (on the 3030, I think it's 5 for the 4000), where you can change whatever you want in the programming, As there is 99 memories, you can still have 33 planes if you use this feature on all of them...
And if you hate flying with a tray, wait a little for the new Royal Evo....
Bernard
