ORIGINAL: CrashBurn69
Will it cause interference if I would use a zip tie to gather up all loose servo wires inside my plane, so they are not flopping around loose?
You could use masking tape or electrical tape, which is softer and will not cause chaffing to the insulator. You could tape the wire bundle to the fuse wall.
