RCU Forums - View Single Post - Spinners and starters
Old 03-13-2004 | 05:24 AM
CafeenMan
Default RE: Spinners and starters
The only thing about plastic spinners and electric starters is that the starter can mar the spinner. If you're careful and don't jam the starter on the spinner - especially when the engine is hydro-locked or even severely flooded, then you can melt rings in the spinner.
But all the spinners I've used (about everything available) has worked fine.
BTW - Dubro spinner nuts are light. They won't help correct a tail-heavy condition. A regular spinner is a lot heavier than the dubro nuts. If you need nose weight, then the Higgley Heavy Hub and a snap on plastic spinner (if it will fit over the nut) is the way to go.
