RCU Forums - View Single Post - YS 1.10 overheating problem
Old 03-13-2004 | 08:30 AM
PineBaron
My Feedback: (38)
Default RE: YS 1.10 overheating problem
Did someone forget to mention fin cooling area. With 30degrees C ambient, you have to make sure there is enough air flow past the head. I am not sure if the Swallow is enclosed cowl or not. Also check for correct valve clearances. .05mm on cold. Plus ofcourse fuel flow as mentioned by several posts above.
I only fly YS engines (all darn Eric Henderson's fault, he introduced me to them, nothing else seems better).
PineBaron
PineBarons R/C Club South New Jersey.
