ORIGINAL: Dave G
I'm certain that I'd never use my receiver battery to drive the glow plugs.(IMHO)
I don't see the problem... current is current... wether it goes to a servo or a plug makes no difference to the battery. And because of the high voltage (4.8V) the current is only a few hundred mA at the most (starting)... and even much less at anything above idle.
These units have a built in voltage cut off: if the battery voltage drops below 4.8V when the glow power is active the power to the plugs gets cut off.
They also have a built in battery monitor: you can tell the condition of your (receiver)battery from the indication led... killing two birds in one stone (or dollar
And anyway, if you are really worried about it you can always supply the glow current from a separate battery.
