RCU Forums - View Single Post - Engine Idle problems
Old 03-13-2004 | 05:36 PM
Jim C.'s Avatar
Jim C.
Default RE: Engine Idle problems
do you still have the plug you used to break it in, in the motor? if so, try a new one and see what happens. if that doesnt cure it, it sounds like the low needle is pretty rich. re set that needle to 1 1/4 out to start with and see what happens. also, you shouldnt try to adjust that needle with the engine running,
