RE: What is the best ARF trainer
Sig LT-40 this is a great trainer. I started with one last year and it has been a great plane. It flys very well is a breeze to take off. And in when you have to float it in dead stick which will happen, it glides for a considerable distance.The plane was very easy to put together, I have assembled 2 other ARFs since then and the LT-40 has the best instructions and is very welll thought out,all of these are big pluses for a beginner. mine has a Saito .56 which required slight modifications but it is a very good combination. Also the size of the LT-40 70" wingspan makes it easy to see.
the Kadet also comes covered in white oracover so you can customize it by adding different trim so you can easily make yours stand out from others at the field[8D]
