RCU Forums - View Single Post - Funtana stab installation problem
Old 03-14-2004 | 08:17 PM
daveopam's Avatar
daveopam
My Feedback: (9)
Default RE: Funtana stab installation problem
That will work Chris, but it's not the best solution. It can put more pressure on the dowells in the front of the wing and cause premature wear. A lot of guys on RCU are lining the holes with brass in the fuse were the wing dowels slide in. I put a 1/4" block behind mine, but I think the brass is a better idea. It might be worth doing no matter what else you decide to do.
david
