RE: R149DP receiver
Thank you twostroker for replying,yes the fail safe is set up to idle down the engine,and close the choke, but it did not. The engine
kept running until I turned the ignition off. I have tested the fail safe before by turning the radio off and it did kill the engine.
The receiver and battery are 12.5" away from the ignition. I use a plastic rod for the throttle and choke. I'm using 8 servos and I've had to charge the batteries after every flite. My receiver pack is a 1400 4 cell.
Its weird on my trainer I would have to fuel after each 10 min. flite and recharge after 4 flites. On the stick I get 4- 10 min., flites on a tank of fuel and have to recharge after each flite.
Thanks again for your time.
Eric
