RCU Forums - View Single Post - Procedure fo maiden flight?
Old 03-14-2004 | 11:01 PM
CARS II's Avatar
CARS II
My Feedback: (7)
Default RE: Procedure fo maiden flight?
I did the maiden flight on my fan trainer today, and it went like this.
The previous weekend, taxi runs, engine checks, fuel sys. checks, retracts checks ( one wheel came off on one of the taxi runs , it could had happened on the first take off then I would have to deal with it )
Check your controls before you taxi and at the runway, right is right , up is up and so on.
Trim the Elevators to be a few clicks on the up position, the airplane will climb giving you time for other tings.
Nose gear steering to a minimum, It becomes very sensitive as it screams down the runway.
When your ready at the beginning of the runway think, if something doesn't look good at the first three seconds of the TO. ABORT, ABORT ABORT.
On my TO I noticed right away that I needed more elevator, so I gave it more elevator, retracted the gear and flew to the right away from the sensitive area ( the road ).
Next I continue the climb increasing the chances of making the runway and keep on climbing to a safe altitude before I touch anything or move anything.
Level off and back on the throttle 1/3, time to trim Elevator few clicks down, Ailerons two clicks to the left, trimming done.
Next, check the high rate and low rate on the Elevators and the Ailerons.
Time for some flying around, loops, rolls, split S.
For the throttle check, position your the airplane on a spot where it can be glided to the runway if the engine goes south, Try half throttle to full, low to half then full, idle for about 30 sec. go to full throttle, if every thing goes OK go fly for some more including slow flight preparing for the landing.
On the landing portion maintain altitude but manage your speed or your plane will fly by you and if it is going to, be ready before it gets there on final think GO AROUND, GO AROUND very early into the final app.
All that you did up there will assure you that the engine will not quit on you at the moment of going around and that you have learned to recognize the slow flight speed of your airplane.
The first flight is to make sure that the airplane is trimmed and that everything is in place for the second and third flight, after that you are out maiden mode.
Best whishes
CARS II
