ORIGINAL: canadianjosh
dude, ill bet that this thing frickin flys (no pun intended) why do you have both engines being run by seperate servos, wouldnt you have a tendacy to have one motor gong faster than the otther,????
The reason for separate servos is for the ease of tuning and throttle control. The engines are both .40's, one is a OS .40 la and the other is a OS .40 FX. Not too much difference here. But with my radio i can have each engine on a separate channel, my setup is left engine on engine channel, right engine on elevator channel. I can mix these channels so that the engine control stick controls both channels, this way when starting i can rev each engine separately and could even if i wanted mix the throttle channels into the rudder channels so that left rudder would back power off of the left engine to aid in turning, however, since my rudders are big enough to flip my boat( happened once allready) i don't need any more turning power, as well i can tune the engines so that half throttle on my radio is half throttle on both engines, most of the time i run at full throttle and then back it off to turn. With that said yes my boat moves, the bottom of the hull is pontoon style so there is only actually about 8 inches of width in contact with the water, it is fun to go full throttle on the water and hit the little sand bank on the beach and get some air, it also moves quick on the ground too, and actually will turn tighter on the ground then the water, i think this has to do a bit with the pontoon design, which makes the hull "grab" the water more. Below is a pic of my radio gear drying out after my flip. The only damage was two stripped servo gears and to my confidence as i watched that thing barrel roll on me. My servos are now waterproofed as they all filled with water, the receiver didn't even have a drop of water in it.
so, is your radio a computer one, if so how many channel and how much was it cus if it's reasonable i might think about getting one......... when you say mixing the servos, you mean that it can combind more than one sensor(servo) into one raido wave and make 2, 3 or even 4 servos move at once,, if so that is soooooooo sweet,
