RCU Forums - View Single Post - Another Prop Question
Old 03-15-2004 | 01:36 PM
iflyrc24's Avatar
iflyrc24
Default RE: Another Prop Question
If you drill the hub you need to be very sure that you drill it in the center. A drill can walk off center or not go through the hub square.
Most of us use a prop reamer. A few different manufactures make them. Great Planes for one. Use a reamer you will have better results.
DEG
