RCU Forums - View Single Post - Hinges - GP Christen Eagle
Old 03-15-2004 | 03:09 PM
captainpitts-RCU
My Feedback: (24)
Default RE: Hinges - GP Christen Eagle
I use ca hinges as well I've had them on a g.p. pitts and a great planes patty without any problem. i have used both g.p. and rocketcity ca hinges and the are both fine. Just make sure you have enough gap between the surfaces and when you seal the hinge line don't get to close to the hinge with the heat because the heat can make the plastic in the hinge brittle.
