RCU Forums - View Single Post - 140L problem, again
Old 03-15-2004 | 07:00 PM
PineBaron
My Feedback: (38)
Default RE: 140L problem, again
Did you check if your fuel tank is not leaking at the seam around the cap? I had that problem with one of my YS installations after about a couple of hundred flights. The leak allowed enough pressure for the plane to fly, till it got worse. A pressure check on the system revealed a slow leak, much more leakage under pressure. Also check the regulator as indicated by others here. I have 4Ls and they all run great. I run YS20/20 or CoolPower Pro Pattern 20 when I cannot get hold of YS20/20.
PineBaron
