RE: flutter on funtana
i had standard servos all the way around on mine. they are fine. I then moved to hitecs cause i had some long aluminum servo arms for them so i could get more throw, that i didnt have anything longer for the standard servos. I still have them on the ailerons. The have sufficient strength as long as you dont do any full throttle passes. good luck.
