RPMTECH your max power is low. Change your pump to the newer style pump and setup your max cp to 1200mb the newer pump will give you max power thats if your not running a six burner or vs the 12 burner. If you want to remover the oil tank use a Y festo connector between the fuel and the oil line. And change the ECU. And as time goes on in stall a starting motor RPM sensor and a AUTO START ecu .
